Running multiple micro leds from a single source
abjay
Joined Mar 14, 2014
10
Hi
I have 5no. sets of micro led lights each with it's own multi function controller contained within a 3 x AA battery pack. I is a pain to go round switcing each set on individually and changing the different batteries as needed. Is there a way of wiring all the sets to a single battery and single switch (I do not need the multi function features, just of and on).The packaging does not give any other information other than running each set on 3 x AA batteries.I can rig up a 24V battery but would I run these in parallel or series, would each set need regulating down. I'm sure there is more than one way to skin a cat. Any suggestions would be very welcome.
Adrian
Dodgydave
Joined Jun 22, 2012
11,395
Yes wire all the leds to one 5V power supply (like a phone charger,)or 6V battery with one switch in series with the power supply.
Your leds are using 4.5V batteries and probably taking 50-100mA each, so a 1 or 2 Amp psu will do.
Audioguru
Joined Dec 20, 2007
11,248
The strings of LEDs can be connected in series (powered from a higher voltage) or in parallel (powered from a higher current).
If you remove the "multi-function controllers" then the LEDs will probably burn out without re-designing a circuit to properly limit their current.
djsfantasi
Joined Apr 11, 2010
9,237
One question? What functions are implemented in the controller?
Blinking? Chase lights? Multi-color?
It may make a difference as to how they’re wired.
