running a circuit with push button
ali sedaghati
Joined Jul 23, 2017
7
hi everyone,
i wanna run a circuit with a single push button ,
i wanna know that using a micro controller is the only answer??
and if it is, is there a simpler micro than atmega 8 that i can use
because it's really a general purpose device??
LesJones
Joined Jan 8, 2017
2,323
You need need to explain EXACTLY what you want the push button to do. Is it just turn it off and on or do you want to enter different commands with a series of pulses like morse code ? There are a number of Atmel 8 pin micros such as the ATtiny13A or the PIC12Fxxx series that are simpler than the atmega series.
Les,
DickCappels
Joined Aug 21, 2008
5,890
1. Q: i wanna know that using a micro controller is the only answer??
A: No, it is only one way to control things with a button.
2. Q: is there a simpler micro than atmega 8 that i can use because it's really a general purpose device??
A: There are many simpler controllers. PIC10F222T-I/OT and ATTINY4-TS8R <== Datasheets are on these pages.
ali sedaghati
Joined Jul 23, 2017
7
Les,
THANK YOU so much , well i need pwm too because i wanna control a dc motor .
can you advise me which one should i go for( atmega vs pic)
