Run capacitor for 1 1/2 HP motor
DMMorgan
Joined Nov 20, 2019
I have acquired an older 1 1/2 HP motor.
The motor works when hooked up to power, however I have not run it under load or for an extended period of time.
I believe the run capacitor currently hooked to the motor is incorrect and would like to verify it's value before using the motor.
I have contacted the Manufacturer Marathon Motors, they cannot find the specs.
I have attached a picture of the nameplate from the motor.
The Run capacitor currently installed is 7.5MFD 370V
MaxHeadRoom
Joined Jul 18, 2013
30,713
Does it also have a start cap, or just run?
For a run on a 2 pole motor that seems about right,
If you do run in to issues you could try another cap (~5uf) in parallel and compare the current when under load.
Ensure it is AC motor run type.
Max.
DMMorgan
Joined Nov 20, 2019
Max.
Yes, the motor also has a start capacitor 270-324 MFD 125V
I have attached pictures of the capacitorsMarathon cap run .jpgMarathon cap start.jpg
DMMorgan
Joined Nov 20, 2019
Max.
If I change the value of the run capacitor and check the current under load, I assume I am trying to get a reading as close to the motors stated FLA as possible. Is this correct?
MaxHeadRoom
Joined Jul 18, 2013
30,713
Correct, but unless you see overheating or lack of power under load, you may be worrying unduly .;)
Max.
DMMorgan
Joined Nov 20, 2019
Max.
Thanks Max, I appreciate your time and your help.
I will keep a close eye on the motor and do further testing. Hopefully my concerns turn out to be unfounded.
