RS232 communcation doubt
viraj.dali
Joined Oct 20, 2016
36
I read about RS232 communication. I have a one end PC which is DTE and at other end is the Data acquisition unit. I want to make communication between this two. But I am not getting clear idea about by which software will PC communicate with Data acquisition unit.
Thank you in advance
Picbuster
Joined Dec 2, 2013
1,058
We can't help you without more information. (it is like the question; how long is a rope?)
Type of pc, data acquisition device operating systems and OSI layers and their protocols used.
Picbuster
viraj.dali
Joined Oct 20, 2016
36
Picbuster
PC is windows 7, Data acquisition device is NI-DAQ USB 6525
DickCappels
Joined Aug 21, 2008
10,661
The manual says "Software support for the USB-6525 for Windows 2000/XP is provided by
NI-DAQmx."
The manual also says "The NI USB-6525 is a full-speed USB 2.0 device that provides..." The device does not make use of RS-232.
Did you intend to mention a different device?
viraj.dali
Joined Oct 20, 2016
36
NI-DAQmx."
DIGEM 96 x 24 MF5 is digital mesauring instrument
cmartinez
Joined Jan 17, 2007
8,760
Yes the device has RS232 output.
So all you need is an RS232 port in your PC/laptop or whatever.
RS232 is only a standard that defines electronic levels/voltages in a serial communications wiring. But it does not define a protocol. That depends on each device and/or design. For us to know more, you need to post the user/hardware manual of whatever it is that you're trying to communicate with.
cmartinez
Joined Jan 17, 2007
8,760
This the user manual.
The manual you've posted is far from being complete. Either there's another more detailed "hardware manual", or the supplier has its own proprietary (private, and not to be shared) communications protocol. If the latter is the case, I'm afraid that none of us can help you out.
