Rotate component in LTspice?
spinnaker
Joined Oct 29, 2009
7,830
What is the best way to rotate a component in LTSpice?
The only way I know how to do it is to select it with the drag tool then use the rotate button on the command bar. But then the damn component gets dragged all the way up to the top of the screen. Is there a better way?
And can it be rotated at angles other than 45 degree increments?
spinnaker
Joined Oct 29, 2009
7,830
Ctlt-R when selected.
Edit: and Ctrl-E to mirror.
Bob
Can you expand on that please?
Still the only way I know to select the component is with drag. And it still is dragging the component to the top of the screen.
What do you mean Edit? Edit menu?
What does Control R supposed to do?
SamR
Joined Mar 19, 2019
5,491
There is a way to stop that screen from slewing around when you try to go up to the toolbar to click. Forgot how... Need someone to remind me...
