Rotary switch but counterclockwise?
gnolivos
Joined Jul 14, 2011
28
I need a 2 position rotary switch but I want it to be “on” when I rotate left, and “off” when I rotate right. Most switches I see operate in the opposite fashion.
Is there a switch that operates how I describe? If not, is there a way to build a simple circuit that will use a common switch but operate in reverse fashion as described?
AlbertHall
Joined Jun 4, 2014
12,652
With a standard rotary switch - one pole, two way - you could just use the common and first way contact and it would work as you want.
MaxHeadRoom
Joined Jul 18, 2013
30,788
That is not a rotary switch, just two position.
If you just want two positions, on & off, you do not need a 'rotary' switch.
You just need a two position switch with the switch element. N.C. or N.O, on whichever side you want?
You can stack them with the appropriate NC/NO options.
The Chinese have reproduced the Telemecanique range quite cheaply.
Ya’akov
Joined Jan 27, 2019
10,292
I think the TS wants a rotary action. The cheap rotary action switches like the ones sold for lamps and the like are just SPST but you rotate them to turn them on. If the TS is trying to use the mechanical action of such a switch to turn something on and off with a motor or something similar, he's barking up the wrong tree but so far the specifications for this part are vague at best.
MaxHeadRoom
Joined Jul 18, 2013
30,788
If you buy the originals and not the knock off, they are by no means cheap!
(unless that was tongue in cheek?!!)
As usual there is a lack of pertinent information we have to work with, my ESP is wearing thin!
