I have a rotary switch that was removed from a radio as a channel selector. It has 3 contacts on one side, and 3 opposite. The center is common on each side. The first set changes from an open to a short every 2 clicks on the left, and every 8 clicks on the right. The second set of contacts has a common in the middle, and changes from a open to a short every 4 clicks on the left, and every 1 click on the right.
I see the pattern 1,2,4,8, so it must be counting, but there are simpler ways to do it, so what is the purpose of having so many contacts when they could have done it with one set of contacts instead of two. The contacts from each side of the switch only have contact with the common from the side it is on.
What kind of circuit would read this switch?
Thanks for any insight into how this switch was being used.
Joe
Joe
