What decides the choice of value of pull up resistors in hall effect sensors?
I have flow sensing system with a hall effect sensor. I was facing some erratic behavior when trying to take out known volume from this sensor. Sometimes it would give out the desired volume in a particular pulse count, sometimes it would give out less. A friend suggested noise and EMI issues, and suggested using a pull up resistor to sort it out. This friend suggested a 10K, but I need to understand why 10K, why not 1K or 100K? How does pull up resistor help sort noise issues, how to choose resistor value.
