RLC i dont understand
michael1978
Joined Jun 29, 2014
309
Hello to everbody can you help me how come C6 to be 10p and c5 13.5 and and l1 to be 190n and L6 240n
i start with 100Meghz, with one circuits 50/XL or 50/XC now become three different thanks
i take it from this tutorial
WBahn
Joined Mar 31, 2012
33,245
How can we possibly tell you why particular components are particular values unless you tell us what the point of the circuit is to begin with, what the goal is, and what parameters you have control over and which ones are fixed?
wayneh
Joined Sep 9, 2010
18,170
The components are those values because the person that drew the schematic chose those values. Without knowing what the designer was trying to do, it's impossible to guess the "why". I would assume the values were chosen to provide a tuned oscillator. If this was all done in simulation, it's probably useless because the components and the PCB itself will have real inductances and such that the model does not account for.
MrAl
Joined Jun 17, 2014
13,812
Just for fun I'll take a guess...
"Transform the filter into a highpass, lowpass, and bandpass".
possibly with some other criteria also such as input/output impedances.
This could be checked out by analyzing all three circuits and see what they have in common.
Just a guess so this could be true or totally false :)
michael1978
Joined Jun 29, 2014
309
i put the tutorial
michael1978
Joined Jun 29, 2014
309
Ok i see you added the tutorial, but perhaps you can explain what you want to know in your own words and why you want to know that.
this
It is very interesting to check the effects of this modifications on the
filter response in Fig.7
The response show that while the filter with
series inductor and capacitor has a symmetrical
response (blue trace), the two inductor filters has
steeper response at higher frequencies (red
trace), this network is normally referred as low
pass coupling
. The two capacitor filter has
steeper response at low frequencies (green
trace), this type of coupling is referred as high
pass coupling
Fig. 7
Note that in the two coupling capacitor filter, the
value of resonant capacitor C5 has been
decreased in order to compensate the frequency
shift caused by the two coupling capacitors, in
the two inductor filter inductance L1 has been
increased to compensate for the frequency shift
caused by the two inductors.
WBahn
Joined Mar 31, 2012
33,245
this
pass coupling
pass coupling
Fig. 7
That's what you consider "in your own words" or telling us what you want to know?
Seems more to me like a direct copy/paste from the tutorial.
MrAl
Joined Jun 17, 2014
13,812
those
Hello again,
Well the goal of any filter is to meet the design requirements which are usually at least:
1. Resonant peak at some particular frequency Fo or Fc (many kinds of network applications),
2. Match input and output impedances (networks like this one).
3. Possibly a certain circuit Q.
That means to find out what values you need, you have to be able to analyze the circuit first, then figure out how to get the input impedance to match the required spec, the output to meet that required spec, and the resonant peak to match the required frequency spec.
For this circuit it looks like 50 ohms, 50 ohms, and 100MHz. That's three things you have to accomplish, and the solution will provide you with the required component values. You may have some arbitrary choice too, such as the output capacitor value which you may want to match the input capacitor value. You may also want a certain minimum Q.
It looks like what they did was design three different circuits to match the input and output impedance (did not check this yet though) and the resonant peak point frequency. They then analyzed the circuit Q indirectly to compare sharpness.
Note higher Q's require more exact component values and less change in component values over the life of the equipment too.
In some circuits you can change values also to get a higher Q. I dont know if you can do that with these circuits or not but you could try to determine that.
So can you analyze this circuit? After that you try to solve simultaneously for component values that meet all the specs.
michael1978
Joined Jun 29, 2014
309
Hello again,
hello thank for answer
yes it is about higher q, but what do you think you have self to select wich is better of there is a formula
the first input load with 50OHM the second reactane in serie with 50OHM is 100OHM load and here is the resultat, but with three circuits they change
michael1978
Joined Jun 29, 2014
309
Hello again,
Yes this is for higher Q
