Hi, Can anyone please help with the attached question. Im unsure as of how to calculate the inductance and show the working. Any help would be appreciated. Thanks!
How do you model the coil? Obviously, as a resistor with an inductor; but are they in series or in parallel? If you were given an RL network, could you calculate the current through it? So if you are given the current but not the value of L then do the calculation in reverse.
real power/apparent power=resistor power/ power apparent for the whole circuit.
Only one resistor is dissipating heat (power).
P=U*I=I*I*R
Pr/Pa=I*I*R/I*I*Z (Attention that here not sure!!!!!!!!)
The series circuit current intensity is the same so it simplifies:
Pr/Pa=R/Z=8/37.46=0,213561131874
