RLC circuit (Critical Damping)
mahboubeh1991
Joined Nov 3, 2016
17
Hi there.
I need to elevate the steady state in this circuit
the next figure shows the output of previous circuit:
How can I modify the previous circuit to be like this output:
Thanks all.
ericgibbs
Joined Jan 29, 2010
21,445
hi 1991,
Have you checked the DC resistance of inductor L2.?
E
EDIT:
Checking your circuit, could explain what you mean by 'elevate' and modify.
Also indicate the node you are measuring
I may have misunderstood.?
mahboubeh1991
Joined Nov 3, 2016
17
hi 1991,
E
EDIT:
Hi ericgibbs.
I sorry for misunderstanding.
The output at node C2 here
And my question is: how can I make the output of this circuit the same as this figure:
in other words how can I make discharge of capacitor at constant value like 0.12v
Thank you.
Mozee
Joined Jul 23, 2016
87
I agree with @AnalogKid .. There will not be and current through R2 L2 C2 when switch is closed because It will short out the circuit and current will pass through the lowest resistance path only which means through the switch loop and not to the R2 L2 C2 loop
mahboubeh1991
Joined Nov 3, 2016
17
Hi Mr.Mozee.
How can I solve this?
Mozee
Joined Jul 23, 2016
87
[/QUOTE]
@mahboubeh1991 Not really, but let me share something with you.
Assuming the switch is opened, I think that the capacitor will never charge because of the inductor in parallel with it, in DC currents the inductor acts as a wire in the end so you are basically shorting out the capacitor from the very beginning, however there will be an instantaneous reversed polarity voltage across the inductor as soon as the DC current reaches it to this phenomenon is called Reactance where the inductor will fight current change through it (which initially was Zero amps) by dropping voltage in the opposite direction but this fight will not last long as the inductor will be fully saturated and will act as a wire with a very small internal resistance and this internal resistance will result in a voltage drop across the inductor, thus, the capacitor (Ohm's law V=IR). Assuming that the internal resistance of the inductor is zero(Ideal) and the cap. is in parallel with it, it will be basically shorted out.
This is as per my knowledge! .. wait for the experts to approve or disagree :)
AnalogKid
Joined Aug 1, 2013
12,142
Without knowing the resistance of the inductor, the initial conditions in post #1 are in question.
Also, 0.125 V across L2 steady state means a significant change of the overall circuit to provide this DC path. If L2 is a large power inductor with a DC resistance of, say, 0.01 ohm, that extra 12.5 A has to come from somewhere.
ak
ericgibbs
Joined Jan 29, 2010
21,445
hi 1991,
This is a simulation in LTSpice of the circuit you have posted.
It shows the state of Vout before and after the U2 switch is Closed.
As you can see it does not give a response as you have posted or required.
Is this Homework or a College assignment.
E
mahboubeh1991
Joined Nov 3, 2016
17
hi 1991,
E
Hi.
Thank you for your interest.
This is my final graduate project.
I was used Orcad 16.6 pspice.
DGElder
Joined Apr 3, 2016
351
Play around with that topology and see what you can get. Given the only quantitative spec you provided: 0.12= Vs*R2/(R1+R2)
You have not provided a full description of the project/problem, the final specification for all the circuit performance parameters of interest nor what degree of freedom you have in your design. So we just throw up random ideas with little to no direction.
