I have looked at this before doesn't give the algebraic expressions I need or the steps to achieve them.Hello,
Have a look at the following page of our eBook:
http://www.allaboutcircuits.com/vol_2/chpt_3/4.html
I have an RL circuit that is currently in series so I know z=RS+XS I need to make this into parallel to get RP and Xp. I have the values for RCould you be a bit more explicit in what you are looking for. Not sure just what you mean by "matching" in this context.
How about stating a problem and showing what you have done so far on it.
I have a series RL circuit with a known impedance I need to convert this into a parallel circuit with the same equivalent impedance. I know Z=RS+XS for a series RL circuit and I have the values of RS & XS. I need to find RP & XS I have seen the following equations in textbooks and on the web but need to know the algebraic method that was used to get to these equations:Could you be a bit more explicit in what you are looking for. Not sure just what you mean by "matching" in this context.
I know RS and XS need to find RP and XP so I have two unknownsThe equivalent resistance of two resistors in parallel (say R1 is in parallel with R2) is:
Requivalent=\frac{R1*R2}{R1+R2}
So. Rs+Xs=z. z is known to you. Rp is given to you.
All you have to do is:
z=\frac{Rp*Xp}{Rp+Xp}
You know z, you know Rp. Solve for Xp.
Then pick any Rp, say 1 kOhm and solve for Xp.I know RS and XS need to find RP and XP so I have two unknowns
Part of the problem likely stems from the fact that Z does NOT equal RS+XS, assuming the XS is the reactance of the inductor.I have an RL circuit that is currently in series so I know z=RS+XS I need to make this into parallel to get RP and Xp. I have the values for R
Rp = (RS²+XS²)/RS
Xp = J(RS²+XS²)/XS
