RJ45 modbus cable to D9 connector
Boardwalk
Joined Jun 5, 2016
3
Hi people,
I have a stripped RJ45 cable to whom i need know how to make the wire connection in a D9 connector, in order to match the pinout of a MPI-Bus adapter.
How should i connect the wires from the RJ45 cable to the D9 connector?
Thank you in advance,
Boardwalk
AlbertHall
Joined Jun 4, 2014
12,630
That depends what you are going to connect the other end of the RJ45 cable to. The XBT ZG9292 cannot be connected to Ethernet however you wire it.
AlbertHall
Joined Jun 4, 2014
12,630
So maybe:
RXD - RX
TXD - TX
RTS - RTS
SG - GND
But I suggest you call the manufacturer. Damage is possible as some 'RS232' ports use 0V to +5V and some use -15V to +15V.
