I'm experiencing weird ripple(I'm not sure should I call it ripple..) when using nfc module(pn532) with esp32
My circuit is simple, connect PN532 (GND, SDA, SCL, 3.3V)<-> ESP32-C3 (GND, SDA, SCL, VCC5V) using i2c
and as I know PN532 has internal LDO, it is ok to put 3.3V in VBAT(=VCC5V) https://www.nxp.com/docs/en/nxp/data-sheets/PN532_C1.pdf
Circuit diagrams are below
<PICO C3>
<elechouse PN532>
problem is here, whenever I turn on nfc scan, there are ripple(?) in VCC 5V <-> GND (Yellow color in Osciloscope) which has 13.55MHz frequency (it seems rfid frequency)
and due to ripple in VCC, wifi in esp32-c3 become unstable (slow or drop ping)
after turn off nfc scan, wifi works flawlessly
so Question is..
- why does ripple happend since there are many 0.1uf, 10uf capacitor which act as high frequency filter?
<PICO C3>
<elechouse PN532>
so Question is..
- 10uf, 13.56Mhz -> Capacitor Impedance 0.0012? https://www.allaboutcircuits.com/tools/capacitor-impedance-calculator/
- how can I prevent ripple?- I didn't expect ripple since I'm using component as complete module (elechouse pn532, wemos pico c3) not IC nor custom pcb
- is it common situation?, how can I know problem happen before soldering module? and how can I prevent this situation?
