Rings for potentiometer
Kris@UA
Joined Apr 29, 2017
18
I bought a potentiometer. It came with some metallic rings of circular and hexagonal shapes. Can someone help me understand their use?
bushrat
Joined Nov 29, 2014
209
Well, when you solder the pots onto your board, sometimes you want to attach the pots the the chassis of your project, so that pots wont break out of your board..
Just an example:
You have 2 nuts, a serrated lock washer and a Bellville washer.
Some potentiometers and switches had a small tab that you drilled into the panel to prevent rotation. The switch ones work a little differently.
The two solid nuts basically allow you to accomodate different panel thicknesses. You want one nut flush with the front panel.
The serrated lick washer "bites" into the panel uniformly.
The Bellville washer I haven;t seen int his application, but it provides a constant torque.
The potentiometer nuts should be tightened from the back with a special wrench,
So Pot-nut-Belleville washer-A-panel-B-nut
The Seated washer should be effective in both the A or B positions. The first nut in the sequence is the one you tighten, so to not mar the panel. Hollow shaft nut-drivers work from the front panel.
In the old days, pots were mounted on a secondary bar and had long shafts,
