Can anyone identify the manufacturer of this BNC connector? It is for RG174 cable and is longer than a normal BNC and has three knurled areas to aid in handling.
I do not have to use the same style connector but it is part of an instrumentation setup and it would be nice if all the connectors were the same. I thought someone may recognize it!This BNC connector does look special. While do you really need the same type? There are so many different manufacturers, pasternack, mini-circuits, amphenol...
I see. Maybe you can take another picture with better quality, then try you luck with google picture search.I do not have to use the same style connector but it is part of an instrumentation setup and it would be nice if all the connectors were the same. I thought someone may recognize it!
