I'm an electromechanical engineer in the middle of a side project and I stepped right in a big pile of RF. I've never really worked with RF signals before so I've done my best to spin up on the field but I wanted to run my design by others for feedback/guidance.
What I'm trying to accomplish in short:
Integrate a two separate VHF transmitting devices into one antenna, and bias the antenna with 3.7v DC.
The first RF device (a gps tracker) operates at 150-155 MHz, short pulses (data) every 5 seconds or so.
The second device (RDF pinger) operates at 145 MHz, short pulses (audio) every couple of seconds.
The antenna will be nitinol wire, 1/4 wave.
I need the tip of the antenna to be at 3.7v DC. I could just run a small wire up the antenna and heat shrink together, but I don't want the antenna coupling to the wire and feeding RF back into my DC supply (unless a simple choke would make that okay?)
I have a small RF power combiner, 2 way, 0 Degree from Mini Circuits.
The plan is to connect each VHF transmitter to the respective ports of the power combiner, and the antenna to the sum port, I have RG174 cable for the transmission lines.
As you can see in the picture, the GPS tracker has an 18inch which landed on a screw lug. There is a metal case around the smarts, which I pressume is an RF shield/ground plane. The first problem/question is that the antenna connector shows continuity to ground(battery ground and to the RF case on the pcb). Is there any issue with just landing the center conductor on the antenna output lug, and tying the coax shield/shell to the RF shield/case/ground?
Secondly, I need to bias the antenna so that there is 3.7v DC present at the tip at all times. I have ordered a 1nF capacitor and a 7uH inductor (with the highest self resonance I could find) to make a bias tee, which I plan to connect just after the sum port of the combiner. This signal (RF and DC) would then go through a short length (3-4in) of RG174 coax, to the top of the enclosure, where I would land the center conductor on the nitinol, and then use copper foil tape to form a ground plane and connect to the shield. Does this seem reasonable?
I purchased a VSWR meter and some unterminated connectors and I plan to temporarily solder it inline with the antenna for tuning, any advice there?
Any and all advice is welcome
