I built a fet input amp to amplify a 11mvpp signal. the source resitance is 0.02 ohms.
It is a 2 stage amp, both stages are identical, each is designed for a gain of 12.5.
I tested it on my bench with a 50 ohm signal generator, the gain of the first stage is 3,
the gain of the second stage is10.
I found that if I put a 6k resistor in series with my 50 ohms signal generator,
the gain of the first stage increase to 8.8.
I don't understand that, but know it will get worse when I use a 0.02 ohm source resistance.
Here is the schematic I used, 2nd amp schematic on the page.
http://www2.eng.cam.ac.uk/~dmh/ptialcd/trf/trf.htm#detector
Thanks for your help.Mikek
