The circuit board is going bad on my heat pump and will cost too much to replace. I'm hoping to make it through the fall/winter before we replace the whole unit. I removed the black wire from the ry101 and removed the white wire from the ry102 relay and attached the black wire there. The compressor now turns on and works. Should this be ok? Or is this wired wrong? I was concerned about the capacitor. I wasn't sure if there was another circuit that controlled it or if everything was turned on through the black wire. The heater circuit that is disabled now off ry102 powered a 3,850 watt backup electric heater. The compressor pulls 2.5 amps during normal operation.
