Rewinding a transformer
Rufinus
Joined Apr 29, 2020
323
Hello.
I have rewind a transformer to get differents voltages. What I have done is every some turns, I got a cable. I show it here
But I have just realised that when a transformer have differents outputs use this configuration
I mean, different windings for each output. In mine, since I only going to use only 1 output each time, should be no problem right?
But I suposse I won't be able to use 2 outputs simultaneously right? I mean, I wanted to run a induction heater with 2 independents power supplies, one for the main circuit (24V) and the other for the gates of the MOSFETs (19V).
I really appreciate any advice.
Best regards
Rufinus
Joined Apr 29, 2020
323
Thanks for your answer.
So I could use the bridge A to give current to the gates of the mosfets and bridge B to the rest of the circuit and they behave like 2 independent power supplies right?
BobTPH
Joined Jun 5, 2013
11,576
Careful, you cannot have a common ground between the two voltages.
You don’t need a separate 19V supply the gates, there are other ways to handle it.
Rufinus
Joined Apr 29, 2020
323
Ah ok. The question is that I have already made the induction heater. I´ll use another power supply for the gates then
MaxHeadRoom
Joined Jul 18, 2013
30,726
To use both windings you require the Va size of the TXMR or an close estimation, based on Primary wire size and and core size.
BobTPH
Joined Jun 5, 2013
11,576
Why not just add a voltage regulator to get 19V from the 24V supply?
We need to see your actual circuit. Perhaps you are talking about using an N channel MOSFET, which is a different issue.
Rufinus
Joined Apr 29, 2020
323
Here is the diagram.
I cut in point A to put a independent power supply. I was said that is important that the gates have current before the rest of the circuit. Because the power suppli for the gates is 19volts, the 470ohms resisors was changed for 100ohm
Dodgydave
Joined Jun 22, 2012
11,395
This is an Induction heating circuit, it just uses one psu 12-15V.
