Reversing relay 230v single phase motor
MaxHeadRoom
Joined Jul 18, 2013
30,820
That contactor is actually a 3ph reverser.
But it should be possible to use it.
You just need to swap the 5 & 8 Connection.
Do you have a pic of the actual motor terminal box connections ?
28,379
The name plate includes both the connection data and the reversing scheme. You will need to remove those six wires from the three phase configuration And arrange for the contactor to exchange the connections to terminals 5 and 8. AND, then use that third pole to control the line feed to the whole motor.
