Reversing a power drill
AlbertHall
Joined Jun 4, 2014
12,653
It appears that this is a universal motor (brushes and a wound field). If that is so then you can reverse by reversing the connections to either the field or brushes.
MaxHeadRoom
Joined Jul 18, 2013
30,815
Check the continuity of each pair coming off the stator. what ever you do, these should always be kept in series with each other and the COM, when reconnecting to COM pair.
The tricky part with the set up on arrangement shown is that the armature appears to be in between each half of the stator. instead of the often customary stator pair separate on one side.
Max.
Ylli
Joined Nov 13, 2015
1,092
You would need to swap the brush connections (eye round) without changing the position of the field assemble. Just rotating the whole assembly 180° will not be effective.
MaxHeadRoom
Joined Jul 18, 2013
30,815
You end up with the same thing as at most, have swapped both over WRT each other.
IOW, you would keep both stationary the way it was, and move each brush lead over, it looks though as each would not reach the opposite side, you would probably need to extend them.
The alternative would be tricky to do as you would need to swap or reverse each of the stator coil wires, as they appear to be each one on either side of each brush holder, instead of connected directly in series with each other.
Max.
