dv/dt is not referring to a change in voltage source, but the change in voltage drop across the capacitor with respect to the change in time.Assume it's completely depleted and t = 0. Cap should act as an open since by definition I = C*dV/dt and since the voltage source is not changing over time, dV/dt = 0 which means the current through the capacitor is 0. This further goes to show me that since the diode is not getting any current (due to being in series with the cap) forward or reverse bias is not possible since the current is 0.
I'm just not sure if my thought process is correct.
