Reusing a motor from a blender
Joe Stavitsky
Joined Apr 5, 2020
141
I got a new Ninja blender (model ss351) a few months back that was DOA. The manufacturer sent a replacement immediately, but I found a blog post on hackaday showing a simple mechanical mod that would enable me to use the motor to drive a flexible rotary tool shaft (Dremel etc). The attached images are the motor, the control board and the power board. The purple wire to the control board is directly from the wall outlet.
Simple questions;
How can I test the motor itself to make sure it wasn't the specific component that failed? Will simply driving it from a bench psu do it? What minimun V/I?
Is this motor viable for this application? Optimally, I'd like continuous speed/torque control with a foot pedal. I'm not scared of building a circuit from scratch (_yet_).
If not viable, can I use it for a pedal powered generator?
I can link to the hackaday post and the rotary tool shaft if necessary. Also, obviously please let me know if additional pictures are needed.
Thanks so much in advance
Joe
MaxHeadRoom
Joined Jul 18, 2013
30,887
Agree, if it has brushes, it is a Universal motor, if you power it up direct to the mains, unloaded, just test it briefly as it will wind up pretty good!
Joe Stavitsky
Joined Apr 5, 2020
141
If it has Brushes, (Universal motor) It is often controlled by Triac etc.
Crap, either that top screw is frozen or they used some adhesive. Regardless, I don't really feel like disassembling it any further,. Here are w more pics. The one with my thumb in it is really distorted though. That top plastic circular piece is at least 4 times as big as my thumb and that cylindrical plastic piece right below the ziptie is about half the size of my thumb.
Should I just call the manufacturer tomorrow?
Thanks again
Joe
