Response to single voiced phrase...
Externet
Joined Nov 29, 2005
2,676
Hi.
Any suggestions to implement a circuit that its output will change state -say from hi to lo- when a pre-defined audio voice message says something like (example) "turn off decoder" ?
No other phrases are to trigger any action, not to work as a complex voice recognition circuitry.
Only one phrase (digitized?) to compare to the input ?
Any dedicated chip capable of such, where a phrase gets recorded and listens for its equal input ?
djsfantasi
Joined Apr 11, 2010
9,237
I had looked into this application several years ago. But my memory had faded and I can’t recommend a specific chip.
But there are solutions.
With your recording and recognizing requirement. You’re likely looking at a module versus a single chip solution. Search for any of these alternatives.
  • voice recognition module
  • speech recognition module
  • voice recognition chip
  • speech recognition chip
danadak
Joined Mar 10, 2018
4,057
You will have to investigate this. mBlock with added Microsoft Cognitive Services
extension added. I do not know if it handles just a word or phrase. If it can do
speech to text you could do this on PC platform with mBlock. V 3.4.12
The pic I extracted shows the block programming gui construction items for speech
recognition from the MS Extension.
I am doing some investigation in this area so cannot offer much advice.
Regards, Dana.
