Hi,Zero Ohms?
Looking into the circuit (shwon in the video) I see a PARALLEL connection of both elements (L and C), am I wrong?
You only quoted PART of my reply. You should NOT do that. That takes some of the information out of context. That's why you are assuming a predetermined context when I set the new context myself.
Here is the original quote:
You see the entire quote (that matters) also includes the calculation for a SERIES circuit with L and C only. Later in that reply, I add R to make it clear how the R affects the total impedance.When we do a calculation like that we take L and C to be ideal, and because there is no "R" there is no resistance. At physical resonance, the L and C become equal to a resistance of zero Ohms. In real life that would probably be rare, but in theory it is always taken just like that, zero. That's so that it makes it simpler to understand the underlying mechanism.
For a series L and C we end up with:
Z=j*w*L-j/(w*C)
and when we set w=1/sqrt(L*C) we get exactly:
Z=0
The parallel calculation is of course different:
Z=(j*w*L)/(1-w^2*C*L)
and at physical resonance this becomes infinite.
It's probably still good that we looked at both of these situations though.
