It’s the same as the supply voltage. We can calculate the resistance total which to two significant numbers is 2.4 volts. We also know that this is the supply voltage which proves the point of in a parallel circuit the voltage is the same.And, again, what does than mean?!? You’re quoting numbers without demonstrating any understanding. Get into practice of completing the problem.
Otherwise, yup, I agree that 2.376 to two significant digits is 2.4. Why should I care?
I have a math, science and engineering background. In school, I had to a) track units, b) understand how when I made calculations what information is data and what is “noise” (meaningless numbers) and finally, how to communicate the meaning of any number I calculated to the professor. Otherwise, my grade was a big, fat zero. Meaning I would fail.
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Running LEDs with no resistors | General Electronics Chat | 24 | |
series resistors Vs. lowering the voltage | General Electronics Chat | 9 | |
| J | Theory Question About Pull Down Resistors | Microcontrollers | 12 | |
Resistors and Johnson noise | General Electronics Chat | 1 | |
| T | Can you amplify a signal with only resistors? | General Electronics Chat | 84 |
