Without a circuit to comment on this question is like asking how long is a piece of string. The current capabilities of a transistor vary considerably and knowing how much the current must be limited by is dependant on, not only the configuration of the transistors in the logic gate, but also the transistors used to implement the gate. For example, current flow in CMOS logic (argueably the most popular implementation - correct me if I'm wrong) tends to only be significant during gate transistions, i.e. in steady-state conditions there is no (read as negligible) current flow from Vdd to ground, and the inputs and outputs tend to drive capacitive loads, hence there is negligible current flow from this perspective. If we are looking at current limiting for the inputs and output to the logic gate (i.e. external to the gate design) then this is a distinctly different question than why they use resistors in logic gates.but then how to know how many Ohms to add, using Ohm law?? beacause i dont know how much the current must be limited
