- Joined Jan 23, 2018
- 28,286
Consider that the same electrical formulas apply to the big stuff as apply to those circuits that fit easily in your hand. Ohms law applies just as well to mega-watts as to milliwatts. The serious difference is the heat generated. Mostly, the way to acomodate heat is to increase the size. So that is why the big testing and control systems would have cages full of cast iron resistor elements. A one ohm hundred amp resistor is going to dissipate ten KILOWATTS of heat, and that takes a lot of mass to handle without melting.
