Resistor sizing (? Watts)
Ian0
Joined Aug 7, 2020
13,201
Is the base not connected?
It doesn't need the base connection (you might need a small capacitor from base to emitter to prevent interference pickup)
Compare with TLP184
https://toshiba.semicon-storage.com/info/TLP184_datasheet_en_20190617.pdf?did=11793&prodName=TLP184
A TLP184 has a better current transfer ratio - you could use that instead. I couldn't remember the part number when I wrote the first reply.
What wattage resistors should be on pin1 and pin2?
Quarter watt, but make sure that they are rated for more than 200V.
CF58
Joined Oct 7, 2022
9
Compare with TLP184
How do I know if a resistor is rated for xxxV? All the resistor listings I see never specify a voltage!
...and I assume that the wiring for the TLP184 is the same as the H11AA1?
Ian0
Joined Aug 7, 2020
13,201
If it doesn't say, then you shouldn't be buying it. (and don't forget you need a working voltage of 325V for 230V AC supply)
Yes. It just doesn't have the base pin. That's better because there isn't an external connection that can pick up interference.
ThePanMan
Joined Mar 13, 2020
937
I am attempting to make a circuit that detects when mains (AC) voltage is present.
Like this?
https://www.amazon.com/Non-Contact-...-Detector/dp/B09WSQQG86/ref=asc_df_B09WSBQXLT
If you're just looking to test a line this will work nicely. If you want something that monitors mains voltage all the time then a night light with the Photo Resistor taped over. If it thinks it's dark out it will light up. Unless there's no power.
Here's a four pack: https://www.amazon.com/Emotionlite-Night-Sensor-Nursery-Listed/dp/B01LQX0BXA/ref=sr_1_9
