It doesn't need the base connection (you might need a small capacitor from base to emitter to prevent interference pickup)Is the base not connected?
Compare with TLP184
https://toshiba.semicon-storage.com/info/TLP184_datasheet_en_20190617.pdf?did=11793&prodName=TLP184
A TLP184 has a better current transfer ratio - you could use that instead. I couldn't remember the part number when I wrote the first reply.
Quarter watt, but make sure that they are rated for more than 200V.What wattage resistors should be on pin1 and pin2?
