Resistor needed for LEDs?
chuco61
Joined Jan 21, 2015
80
This is probably really simple.
I have 20 Diffused 5mm Slow Fade Flashing RGB LED's that I would like to have operate at the same time. No programming, no micro controller. Just a simple 5v wall power, a pcb and LED array.
Is this simply a matter of wiring them in parallel, adding a resistor at the + side and hooking the whole thing up to my 5v supply?
If so, what resistor would i need to keep the whole thing safe?
These are the ones i have:
https://www.adafruit.com/product/679
Along with powering the LED array, I need to power an Adafruit effects board that needs 5v of power.
If i used the wall adapter below, with a split USB cord so that I can power the LEDs as well as the Adafruit 5v sound effects board. https://www.adafruit.com/product/501
Do you think this would work?
any opinions?
Reloadron
Joined Jan 15, 2015
7,893
About your LEDs:
  • 5mm diffused RGB LED
  • Two leads
  • Power with 3-3.4VDC
  • Current draw: 10-20mA depending on voltage and displayed color
You have a 5 Volt supply so roughly we get Vsupply - Vled / Iled which works out to be about 120 Ohms series resistors. Each LED to have its own series resistor and the parallel them. Do not parallel the five LED and use a single resistor. The supply looks to be 5 VDC capable of 1 Amp so it should be fine unless beyond the LEDs your board has a very hign current draw.
I based the 120 Ohms on Vf = 3.2 Volts and If = 15 mA.
Ron
chuco61
Joined Jan 21, 2015
80
Reloadron,
so i would put a 120ohm resistor for every 5 LEDs? Then all the groupings would go to a common power supply? Like this diagram, assuming that the battery is 5v and there are 5 LED's instead of 3.
#12
No, you use a resistor for every single LED. There is not going to be a series connection of LEDs because 5 volts is not enough to light up 2 of your LEDs in series.
Reloadron
Joined Jan 15, 2015
7,893
What #12 said, one LED and One resistor in series with it. Then parallel the series LED / Resistor combinations.
Ron
18,132
For what it's worth, you could run those LEDs at 5mA and they'll be plenty bright as indicators. Bigger value resistors, less current drain on the battery.
18,132
The heat they need to dissipate should be less than 1/8W. The calculation is P=I^2•R. If we're talking about 15mA: P=(0.015A)^2•120Ω = 0.027W, so those will be fine.
Depending on your plans, you might want to consider an assortment such as this.
chuco61
Joined Jan 21, 2015
80
Thank you!!
Does anyone have a link / resource to blank perf boads that I can use to wire / solder all these LED's? I have about a 5x5in work area to display these in a 4x5 grid. Frys may have some, I just havent looked closely.
Thanks!
chuco61
Joined Jan 21, 2015
80
Back with another question but along the same lines as the above posts.
Is this schematic correct to create a simple sound activated LED circuit? I am looking to use some standard white LED's (and am assuming that a 120k resistor as mentioned above would keep the circuit safe?
I can get the TiP31 from frys as well and will use 5v usb power. Thoughts?
#12
You are back to the, "guaranteed smoke machine".
There were no 120k resistors mentioned.
Whether it works at all depends very much on the amplitude of the signal. Too little and nothing happens, too much and the LEDs smoke. A bit more than that and the transistor breaks over backwards (voltage-wise).
chuco61
Joined Jan 21, 2015
80
hmmm, i think there wont be enough signal from my sound source, it's an old payphone handset that is providing the signal. I'll find an alternative.
Thanks!
