resistive circuit question
Alex1700
Joined Jan 12, 2020
107
Hi guys,
May I know to find the current IS3 why are able to use KCL because there are 3 voltage sources (20v, 5v,8v) in this circuit how is the current distribution? normally using KCL only have one current source
Jerry-Hat-Trick
Joined Aug 31, 2022
823
Why Gustav was given credit for making Georg's elegantly simple law more complicated has always been a mystery to me.
Use Ohm's law. Va = 20 volts. Vb = 20 - 5 = 15 volts, Vc = 8 Volts.
So I1 = (Va-Vc)/R1 = (20-8)/10 = 1.2A and I2 = (Vb - Vc)/R2 = (15-8)/4 = 1.75A
Since the arrow for IS3 is drawn pointing the wrong way the current is the negative sum of 1.2 and 1.75 = -2.95
If you are being taught to do unrealistic problems using Kirchoff's laws I'd recommend looking for a better course. I've interviewed so many new graduate engineers who can do this kind of problem but have no idea how to address real world problems.
Alex1700
Joined Jan 12, 2020
107
may I know there are 3 voltage sources how is the KCL able to apply ?
Jerry-Hat-Trick
Joined Aug 31, 2022
823
why are these cases able to apply KCL based on nodes?
Alex, you may not have understood my point. KCL is, in my view, not worth your time. Honestly, since I've never seen the point of KCL, at least in real world problems, I'm not the best person to give you a sensible answer. Why do you care? The circuit in your post is completely artificial, which is why I recommended finding a better course which teaches and tests real world problems.
Alex1700
Joined Jan 12, 2020
107
Hi Jerry-Hat-Trick
Any recommendation course that teaches real-world project
