Are e any texts e who explain how to find the resistence seen by a capacitator,and when there are other capacitators on the circuit,to know if they are indipendent or not
What do you mean with "resistance seen by a capacitor"?Are e any texts e who explain how to find the resistence seen by a capacitator,and when there are other capacitators on the circuit,to know if they are indipendent or not
As I see when V1 is turned off, two voltage-controlled current sources are zero. So impedance seen by CD will be Z = RD1 + R|| 1/(sC) + RD2 and the resistance is the real part of Z. It depends on C.fors example find the resistance seen by Cd,with the generator V1 turned off ,and let's put a generator Va in Cd and let's measuce the current at its terminals and see if the other capacitor C influences or not the resistance seen by Cd,I mean if we consider C open does it influence the resistance,what if we consider it closed
So in a PCB after multimeter measurements R1 or C1 which one of them are destroyed or something like that?As I see when V1 is turned off, two voltage-controlled current sources are zero. So impedance seen by CD will be Z = RD1 + R|| 1/(sC) + RD2 and the resistance is the real part of Z. It depends on C.
by Robert Keim
