Repairing a Tact Switch
lothian1
Joined Jan 6, 2021
13
I've confirmed tact switch in the image isn't working. I figure I'd simply replace the thing, but it seems affixed with unobtainium solder--the stuff just won't liquify. I'm considering cutting its leads and replacing it with a surface-mount equivalent. It occurred to me that perhaps a soak in a solvent-based cleaner might work?
Anyone have tips for removing these diminutive components? How about performing necromancy on seemingly dead switches (i.e., likely corroded contact)IMG_0695.jpg?
bertus
Joined Apr 5, 2008
22,998
Have you confirmed all connections?
As you can see there two pairs of pins connected together with a switch in between.
Bertus
lothian1
Joined Jan 6, 2021
13
yup--I confirmed (all) the connections.
For grins I dissected the thing in situ, cleaned the contacts and the underside of the diaphragm doohickey with solvent, reassembled and... voila... the switch works perfectly. corrosion was suspected; corrosion is confirmed.
a buddy has a set of orthodontists tools. i'll borrow his side cutters and nip this thing from the pcb. i've never bought a tactile switch before--i presume i'll have to order its replacement based on dimensions, mount-type, and pole.
Lo_volt
Joined Apr 3, 2014
373
Is it just one or two of the pins that doesn't melt or all of them? It's possible that one or two of the pins is connected to a ground plane on the PC board. The ground plane is an expanse of copper that may sink heat away faster than your soldering iron can heat. They are notoriously hard to solder and de-solder.
I'll second AlbertHall's suggestion to cut the pins and de-solder them one at a time. You may not be able to heat all of them at once, but one at a time should work.
