Hello there! I'm trying to repair a LED emergency light but I've found a problem. I have 2 of those lamps (one works fine and the other doesn't). I think I've identified the problem but there are components with no markings so I can't identify them. (See photo.)
My questions are the following:
- How do I identify which diode is this (in red)? My guess is that it is just a fast schottky diode, but which model?
- If my guess is correct, can I put a 1N4148 (DO-35) instead?
- How do I identify the zener diode (in yellow)? Measuring with a multimeter I read 3.5v across it. My guess is that it is a 3.6v zener diode since they are available in the market and with that package (SOD-80).
- If my previous guess is correct (or not), can I replace that diode with other (same zener voltage) but with a DO-35 package?
