Repairing A Data Cable
RdAdr
Joined May 19, 2013
214
How would you go about repairing a data cable that does not work anymore?
It has two end connectors and it is not cut in half or anything.
I would first cut the ends and see if the pins of the connectors and the wires inside the cable are making connection. If the connections are good, then the fault must come from the cable itself.
Thus I would cut the cable in two and check for continuity. Thus, one half of the cable should be broken, while the other half hopefully good. Then cut the bad half again in two and check again for continuity.
And I do this until I find the location of the fault. Or maybe if I am satisfied with a shorter cable, I would just use the good half, maybe the good half plus the other good half and stop the cutting.
Is there a better method?
ericgibbs
Joined Jan 29, 2010
21,443
hi,
Cables usually fail close to the connectors.
Remove the cable connector clamp, unscrew the connector cover.
Inspect the solder pins for any broken connections.
LIGHTLY pull on each wire in turn, if the wire is broken close to the connector, the pulled wire will come out.
Repeat for both ends.
Which type of cable is it.?
Good Luck.
E
tom_s
Joined Jun 27, 2014
288
post 2 is great for broken connections
the cable you should be able to check for continuity with a multimeter
my question - is it worth spending the time to repair it?
data patch cables - cat4/5/6/sata/esata/hdmi/ribbon etc are cheaper to buy new than to repair.
from my experience, cables are not the issue, sockets are normally at fault, bent pins, dry/cold joints/oxidised contacts
#12
There are ways to inject an oscillating signal and search for where it stops radiating. Problem: Data cable isn't rated for 120 VAC so the cheap electricians pen style detector is a risky method. You have already defined the, "half interval search", but the ends are almost always the culprit. I have seen exactly one cable that was broken in the middle in 40 years of doing this kind of repairs.
RdAdr
Joined May 19, 2013
214
hi,
Good Luck.
E
Some cable used in automotive engineering when testing ECUs through HIL simulation. I do not know its particular name. I don't think it has one. One end is a D-Sub connector, while the other end is a Lemo connector.
Good method. i did not think about pulling out the wires.
RdAdr
Joined May 19, 2013
214
So to look first at the connectors. Thanks.
It is worth spending time, why not. It is a good cable.
RdAdr
Joined May 19, 2013
214
Thanks for answers. So the connectors might be the problem with high probability.
Now the question is. Which connector from the two connectors to cut first and verify?
Maybe just try my luck.
dl324
Joined Mar 30, 2015
18,331
I'm surprised you can buy one for less than $200, but you can.
If you have a scope, you can make one with a suitable hex inverter, a handful of R's, C's, and misc hardware.
If the connectors aren't meant to be opened, knowing which one was bad would be an advantage.
I wish I had one 35 years ago when I had some contractors install multiple 400' runs of cable from a computer room to offices. The gorillas pulled for all they were worth and damaged a number of the ends. Fortunately, the connectors could be disassembled. But it was a hassle having to do both ends on multiple 7 conductor, 25 pair, and 40 pair cables.
#12
A Time Domain Reflectometer could indicate where the fault is, but you need to know the velocity of propagation for the cable.
Since we're still beating this horse, I would mention that you can find the propagation speed by measuring one of the good wires.
RdAdr
Joined May 19, 2013
214
I saw that the connectors were meant to be open. I opened them and one was bad. The pins of the connector weren't making contact with the wires inside the cable no more. But I fixed it.
