repair broken wire in 2N6308
kubeek
Joined Sep 20, 2005
5,796
I think those wires are aluminium, so you will have a very hard time repairing that. Why don´t you just get a new one?
And as you can see, one learns through his errors :)
mostafa_gordy
Joined Feb 28, 2012
57
FOR recreation
you what is think
ink part number is easy cleareing! by hand sweat?!
is not fake:confused::eek:
kubeek
Joined Sep 20, 2005
5,796
If you´re asking if it´s fake or not, I frankly have no idea. You can try ordering another from farnell or digikey to get something to compare.
Anyway, for 125W that die looks pretty small, and if the numbers go off very easily, then it might be fake.
absf
Joined Dec 29, 2010
1,968
Transistor Polarity:NPN
Collector Emitter Voltage V(br)ceo: 350V
Transition Frequency Typ ft: 5MHz
Power Dissipation Pd: 125W
DC Collector Current: 8A
DC Current Gain hFE: 60
Transistor Case Style: TO-3
Collector Emitter Voltage Vces: 5V
Current Ic Continuous a Max: 8A
Hfe Min: 3
Package / Case: TO-3
Or get a substitute. It costs more than $5 in single quantity in Farnell (element 14).
Allen
mostafa_gordy
Joined Feb 28, 2012
57
Hfe Min: 3
Allen
if repair transistor better for me iam not rich similar to.
i use 2n6308 for Transistor Ignition !(by Darlington circuit)
bux15 is substitute 2n6308
or ......
38,780
I'll probably regret asking this, but why would anyone cut open a transistor and then expect to use it? :confused: Transistors are sealed for a reason.
And no, the wire can't be soldered.
bertus
Joined Apr 5, 2008
23,003
NEVER open any transistor, as they MAY contain beryllium oxide, wich is carcinogenic when made to dust.
Safety
Like all beryllium compounds, BeO is carcinogenic and may cause chronic beryllium disease. Once fired into solid form, it is safe to handle as long as it is not subjected to any machining that generates dust.[9] Beryllium oxide ceramic is not a hazardous waste under Federal law in the USA
http://en.wikipedia.org/wiki/Beryllium_oxide
Even small amounts that entered the body can lead to death over time.
35,144
Very unlikely. Why was the wire broken? Because you tried to cut the case open.
The transistor was bad in the first place.
spinnaker
Joined Oct 29, 2009
7,830
wire is not melt and silicon chip is looks good (clear ) ...?
Just because it "looks good" does not mean it is good. It was not designed to be opened. Even if it was working when you opened it, it won't work anymore. At least not for very long. You need to buy a new component. I'm sorry you cannot afford it.
