Removing li-ion battery from philips sonicare
Cretin
Joined Dec 13, 2012
69
I've pried apart my philips sonicare hx6750 toothbrushed and revealed its oh so glorious battery. It's a Li-ion (3.7V) battery, and I want to to remove it to connect it to a 3.3 V power supply and provide it with a bit of charge so I can get it working again.
However, I can't get the battery out! Here are some pictures below. I tried to pry it from the end with an exacto knife and the top of the knife broke and got lodged in between :(
I googled and couldn't find anything for my particular model, so I'm out of ideas and would appreciate any help!
dick56
Joined Apr 27, 2011
30
Is it glued in with that clear glue like used on some of the small batteries on mother boards?
Alec_t
Joined Sep 17, 2013
15,156
Are you intending to keep the toothbrush? If not, judicious use of a hacksaw might do the job :D.
35,181
Again, for maximum reliability, the battery would not be using simple pressure contacts. The contacts would have been spot welded to the battery and then soldered to the circuit board.
Alec_t
Joined Sep 17, 2013
15,156
I agree with Mr Chips. I had to replace a battery mounted that way in a Braun toothbrush. Your second photo seems to show two soldered pins protruding from the board in line with the two ends of the battery.
gerty
Joined Aug 30, 2007
1,305
The toothbrush I disassembled several years ago had the battery epoxied in place with some sort of hard, black epoxy.
