Hello, i require some advices again. I believe you all know this arrangement of switches:
It allows a person to switch the same lamp at two differently located points in a house. In my case the second switch needs to be remotely controlled, so a electronical switch i mean. The problem is, first i designed the circuit using a HT12E and a HT12D sending a bit of information through a commonly used 433mhz ASK module, so i sent the information of the pressed switch that was on another room to control a relay on the main circuit, but the relay needs to be constantly fed, so i latched it with a CD4013 D Flip Flop type, it worked... But the thing is when the circuit first power up the position of the relay is always the same, the circuit does not "remember" the last position it was so it would keeps things natural, like if it was a mechanical switch. And without a bistable latching relay, a thing that is out of my reach for now, i don't know how to do it. I would like the relay that is remotely controlled to remember it's position, or even another device to remember it. It's not really necessary, but i would like to see some approaches to this problem. Thanks in advance.
