Remote Doorbell
Status
Not open for further replies.
wayneh
Joined Sep 9, 2010
18,104
A friend's remote doorbell has failed. This is the part that plugs into the wall and makes noise when the remote button is pressed. It's stone-cold dead. No indicator LED, nothing.
I popped it open and as you can see, it uses a capacitor power supply. I find full AC mains voltage across the big ceramic capacitor, but no voltage on the larger electrolytic. There's also no voltage on the zener, although there seems to be a coating that might be interfering and making it hard to connect my multimeter probes. I have not checked the voltages on the bridge rectifier M10S.
My question is, does this kind of supply fail in a predictable way? Is it common for the ceramic cap to fail, or the zener? I'm just trying to get a feel for whether it's worth trying to repair this thing. I guess I could put 12V onto the electrolytic and see if the rest fires up.
AlbertHall
Joined Jun 4, 2014
12,625
That large brown capacitor is the likely culprit. If you can check its value you will probably find it is very low. You need a class X2 capacitor to replace it.
wayneh
Joined Sep 9, 2010
18,104
I give up. I tried pulling that 1000µF electrolytic. It holds charge for at least minutes. Placing 5VDC across the empty pads caused slight arcing. It's obviously pulling too much current there. So there's more wrong than just the power supply.
DickCappels
Joined Aug 21, 2008
10,661
I am sorry but we are not allowed to discuss this.
Check the User Agreement. Our hands are tied.
  • Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Any kind of jammers (ie - Phone jammers)
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
  • If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
