So how are those used - do you stick them to the underside of the existing button?If the problem is with the buttons, you can buy replacement pads, like: https://www.ebay.com/itm/1-5mm-10mm...ontrol-Conductive-rubber-buttons/263577546395
Yes. In some cases you might have to trim off the existing pad to fit.So how are those used - do you stick them to the underside of the existing button?
You’re welcome. Did you get it fixed? How?Thanks for all the help folks, the info that has been offered has been very educational, which of coarse is the whole idea. The help has been appreciated.
