Remote control of DC motor
xxxyyyba
Joined Aug 7, 2012
289
Here is schematic that provides polarity inversion and switch off motor if it reaches one of its two end positions:
SW1 is On-Off-On DPDT switch with the center position Off. SW 2 and SW 3 are limit switches. Motor voltage and amperage are 12V and 2A (max.). Is it possible to control motor remotely, instead of manual control using SW1? If yes, can you provide me schematic? Thanks in advance
xxxyyyba
Joined Aug 7, 2012
289
Wireless, of course :)
I need simplest solution. It's not neccessary to be remote control using RF, it can be using IR.
30,714
Two conductors out to the motor with each FWD & REV N.C. L.S. all in series, wire a rectifier across each N.C. switch which when the switch is opened, it will be forward biased/allow for the opposite direction/polarity.
I can post if still needed.
