Remote control codes for a television...
Externet
Joined Nov 29, 2005
2,683
Hi. Is there any hope of finding a chart/list of the remote codes emitted in infrared that control a TV ?
I can read the emission codes from the remote with an oscilloscope, but how to find out if they are correct for the TV to respond properly ?
How rare would it be for the codes to corrupt/alter ?
TV is a Vizio M470SV not responding :( to its confirmed emitting remote.
35,320
Was the remote supplied with that TV?
There is a lot of information on the web about remote controller codes.
Have you tried replacing the battery in the remote controller?
There are, but you need to find them and for your model, e.g., http://www.remotecentral.com/cgi-bin/forums/viewpost.cgi?925066
There are also know problems/solutions with Visio IR receivers, e.g., https://www.shopjimmy.com/vizio-3632-0172-0189-ir-sensor.htm https://www.youtube.com/watch?v=orIrNKzryDo
I would suggest another step first. Read your remote code with an Arduino and an IR receiver and see if it is clean. You can even clean up the received signal and rebroadcast it to test the Visio, e.g.,
There is lots of info and code out there on this subject., e.g., https://github.com/z3t0/Arduino-IRremote
Externet
Joined Nov 29, 2005
2,683
Thanks.
Yes, original remote, confirmed it is emitting IR as seen with a camera.
Any site suggestion to find what is its corresponding power on/off code ?
Not listed on 'remotecentral' link :(
Thanks.
Not beyond the ones I posted, you will have to search. But, there are many common codes...don't expect all unique codes for each model - many Vizio will be the same across a number of models.
