Hopefully you will bear with me, I am rubbish at reading diagrams
The bottom float should control the system fully, turning the pump on and off, correct?
Should the bottom float go faulty and the timer has ended it's timed cycle, the pump shall stop?
The top float is only going to be used in the extreme condition of the bottom float welding closed and the timer overunning or going faulty, the 2nd float shall open and stop the pump, this is all to stop lots of freshwater getting pumped into a saltwater tank
