Relay logic validation
metermannd
Joined Oct 25, 2020
472
It looks like I'm coming down to one of the last design hurdles in my project - see the image attached.
After cleaning out unused sections of the original design, I am left with a single channel in use on the ULN2003A driver IC, as shown on the left side, so it would be better to replace the IC with a discrete equivalent, freeing up some real estate on the board.
I want to be sure the circuit on the right side has the same functionality, that the relay is activated when the RLY line is brought to a logic '1'.
ericgibbs
Joined Jan 29, 2010
21,439
hi m,
On the left circuit , the Relay will energise when the input to the ULN is High.
On the right side circuit , the relay will energise when the input to Q5 is Low.
You do not need two transistors.
E
ericgibbs
Joined Jan 29, 2010
21,439
hi,
The MC6921 outputs 5V when High.
So for 5mA Base current, thats 5V - 0.7V == 4.3V/0.005A = 860R, I would a value between 470R and 1k for the R11 into the Q4 Base.
OK.?
E
metermannd
Joined Oct 25, 2020
472
Before I add another line to my project BOM, I do have entries for 510 ohm and 1K...
Assuming you mean that at least 5mA is needed to turn on Q4, would the 510 ohm resistor work?
Also, for clarity, as I understand the 6821 has different arrangements for the 'A' and 'B' outputs, this is driven from one of the 'A' outputs.
ericgibbs
Joined Jan 29, 2010
21,439
hi,
Have you read this section of the d/s, regarding the PortA and PortB outputs when set to OUT.?
What do you see as the difference.
E
metermannd
Joined Oct 25, 2020
472
Spidey: I could - and the 2N6427 comes to mind...
Eric: I assume we're looking at the same datasheet, and this should be a page or so down:
Just want to be sure. :)
ericgibbs
Joined Jan 29, 2010
21,439
hi,
Just set the A or B pin that you are connecting as an OUTPUT pin.
The other features of the pin when set as an Output ie: INPUT or TRI State are not used for your Application.
E
eetech00
Joined Jun 8, 2013
4,705
The output will usually go tri-state at boot up even though your not using a tri-state function.
Use a 10k pull down resistor from the base of the drive transistor in post#6.
