Hi:
I have a 5 volt relay that requires 70mA of current in order to energize the coil.
I am trying to get a driver to work using a 2N3904 transistor, a 1N4148 diode for
the flywheel and a 1KΩ resistor on the base. The emitter is grounded. I want a 5
volt level on the base to trigger the relay. It just doesn't work. Any ideas?
Thanks
Thanks
