Relay Driver
aac044210
Joined Nov 19, 2019
178
Hi:
I have a 5 volt relay that requires 70mA of current in order to energize the coil.
I am trying to get a driver to work using a 2N3904 transistor, a 1N4148 diode for
the flywheel and a 1KΩ resistor on the base. The emitter is grounded. I want a 5
volt level on the base to trigger the relay. It just doesn't work. Any ideas?
eetech00
Joined Jun 8, 2013
4,705
Hi:
Sounds like it should work.
Maybe something wired incorrectly or a bad/incorrect part.
AlbertHall
Joined Jun 4, 2014
12,625
Is the relay operated all the time or never operated?
The circuit as drawn should work so it would seem it is not connected as per diagram.
Give us some photos. We may be able to see the problem.
