I will bread board it up and test it for operation, what I will check for is when I lower the voltage with the power supply down past 11 volts the LED will go off and then I will rase the voltage to 12.05 volts just like a battery will act when the load is removed and hope the LED remains off.
Thanks for your help by the way. I hope you get to vegas sometime to spend your money.
