Relay 12V help please
eddyyoung
Joined Oct 9, 2024
I am putting power supply DC/DC step up 12V to 14V in the car. I would like to use relay to turn on/off when I start and turn off the car.
DC to DC are using 8 awg wire coming in from 12V battery.
Which would be better for 4 pins relay. Seen the first relay with the M6 stud terminal so it might be good for 8 awg wires.
The second one regular relay. But not sure which is best for my purposes. Please advise.
Thank you,
https://www.amazon.com/gp/aw/d/B07T...&pd_rd_r=2915d766-a947-4506-9c28-b26bae084aea
and
https://www.amazon.com/Bosch-033201...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
sghioto
Joined Dec 31, 2017
8,744
Depends on the current the converter is rated at.
#8 wiring is generally rated at 40 amps so choice #1 would be my recommendation.
